32 Panel Pattern
sen
32 Panel Pattern
Post by sen » 22 Sep 2004 12:18
I was told that the soccer ball design found on www.footbag.org isn't good. I was wondering if anyone knew where to find a good pattern for one.
MrRoboto
Post by MrRoboto » 22 Sep 2004 12:26
The 32 panel footbag, which is the same pattern as a soccer ball is definatley the preferred footbag. I recently made a set of patterns of my own because I found the ones on footbag.org lacking.
http://modified.ca/footbag/viewtopic.php?t=6311
I prefer the hexagons with the larger red areas.
These are the only other patterns for 32 panel bags I know of on the web.
sen
Post by sen » 23 Sep 2004 11:20
Thanks for the template but I'm not sure I understand exactly how it works. Could you explain it to me?
lightningbolt
Nothing Vulgar
Post by lightningbolt » 25 Sep 2004 18:47
Yeah, I need help too. It tried to used your templet but I screwed up. :oops:
I think I going to take over Canada. You should help.
Get Firefox!
