['what is this trick called?']
- Spontaneous Spaz
- Spontaneous Spaz
- Spontaneous Spaz
- SandWraith
these have probably been posted before, but here's a link to a tricklist that has a lot of the moves on it in Jobs' and by nickname: http://www.geocities.com/trippderelict/index.html
same thing here:
http://www.modified.in/footbag/viewtopic.php?t=2871 (that's stickied under General Footbag)
And I don't really get what move you're describing, Spaz. The description doesn't match up with your jobs'. You say it ends in a butterfly, but that's an out dex, not an in. As far as your description on the bottom, I think you're saying all 3 dexes are out-in and done with the same foot, like a barfly with and extra dex in it. I don't know what the clipper version is called, but Jorden hit the equivalent from toe and named it triadon (paradon is toe > op out > same out > op clip).
Also, it depends if those dexes are uptime or downtime. Often people use >> to designate when the bag moves from uptime to downtime. Then what I think you're talking about might be a nuclear DOD.
same thing here:
blog
blog
- ObArA'BaRs
- Flower Child
whats a symp whirling set to symp rev. whirl
symp whirl uptime> symp re. whirl down
bling blang but symp
and
whats symp whirling set> symp whirl
Doe the set get a symp add?
I think it does
and
I think it does
- ObArA'BaRs
- Flower Child
- zeroman13
toe > op out (dex)(no plant) > same in (dex) > (symp) op out (dex) > same toe (delay)
Would this be muted tapping symp dlo?
- ObArA'BaRs
- Flower Child
some answer my question please.
ITs an uptime symp whirl>downtime symp reverse whirl
Does it have a name?
- save.cullen
- Spontaneous Spaz
