Matt K
- Flower Child
by Matt K » 15 Aug 2006 08:37
Stepping In-DaDa Curve? I'm not really sure how to name a spin after a stepping set, but it's probably Inspinning.
Matt Kemmer
- modiphile
by BenRea » 30 Aug 2006 18:55
toe set> opp in dex> opp out dex> same toe delay
by zeroman13 » 30 Aug 2006 19:30
BenRea wrote:toe set> opp in dex> opp out dex> same toe delay
This sounds like tap, atomic ss mirage.
max
- Australofrenchbrityorkus
by max » 30 Aug 2006 23:20
zeroman13 wrote:BenRea wrote:toe set> opp in dex> opp out dex> same toe delay
actually that sounds like like a toe set dlo (if done all downtime).
Maxime Boucoiran
French ConneXion
BFC
- modiphile
by BenRea » 31 Aug 2006 06:32
yup, all downtime, its DLO, thanks max.
vettehunter123
by vettehunter123 » 04 Sep 2006 20:12
I don't know what this trick is called but I can do it. Any stepping tips would help also. Thanks guys.
The video is only 21 seconds, just click on the picture to open it.
Travis Iden
Iron Clad Ben
- Superior Precision Bionics
by Iron Clad Ben » 04 Sep 2006 20:32
Travis that's a toe-set dada curve
Props! It's usually people's first 4-add because it's arguably easier than a lot of 3's.
Stepping set! Dude it's looking pretty good. Good luck on hitting something out of it soon!
DanielWhittle
by DanielWhittle » 08 Sep 2006 07:10
I can't hit this yet but i was wondering, what is a pixie set mirage?
like right foot in out dex straight into a left in out dex into right toe del.
? pixie mirage or does it have a different name ?
Daniel Whittle
14 Years Old
UK Shredder
- space cowboy
by james_dean » 08 Sep 2006 07:12
smear
Spontaneous Spaz
by Spontaneous Spaz » 11 Sep 2006 15:18
wut is:
toe> ducking[bod] > op out[dex] > osis[bod][xbd][del] =5add?
by Zac Miley » 11 Sep 2006 16:22
Ducking Dyno maybe?
- modiphile
by BenRea » 11 Sep 2006 16:29
yup yup.
DanielWhittle
by DanielWhittle » 25 Sep 2006 12:14
Toe same legged in>out dex same legged clipper.
and 3 adds i presume?
Daniel Whittle
14 Years Old
UK Shredder
Iron Clad Ben
by Iron Clad Ben » 25 Sep 2006 13:01
DanielWhittle wrote:Toe same legged in>out dex same legged clipper.
Toe Whirl. 3 ADDs. Propskies.
by Zac Miley » 25 Sep 2006 17:02
That sounds more like toe ss drifter to me.
I dunno.
Do you mean the leg that you set from is the leg that does the dex, and then the leg that does the dex delays it on a clipper?
DanielWhittle
by DanielWhittle » 25 Sep 2006 22:39
yeh, i think islwar was right, it was a toe ss drifter, my right leg sets , my right leg dexes and then my right leg catches the footbag in clipper delay. I aint landed it on flipside yet but i guess that will come soon enough
Daniel Whittle
14 Years Old
UK Shredder
- modiphile
by BenRea » 26 Sep 2006 10:48
after your leg dexes the bag....does the bag go in front of your planted leg before you clipper? otherwise it would be a dada curve
DanielWhittle
by DanielWhittle » 28 Sep 2006 12:53
the bag goes behind my support leg for the clipper so its kinda like osis but with spinning if you get me.
Daniel Whittle
14 Years Old
UK Shredder
by zeroman13 » 28 Sep 2006 14:17
then it's dada curve, not drifter.
