Around The World (ATW)/Around/Orbit
JelloFootbags
- Hack Fiend
ATW
Ok...I do the around the world from a toe set but i land on a inside delay...is it still a around the world? Also...What would it be if I do the ATW throw up the inside delay and do a in to out dex with my left leg and delay it on my right foot.
I footbag...because its freedom.
Zack Cizek
Big fan of Jorden Moir =D
Zack Cizek
JelloFootbags
- Hack Fiend
- jbalexdarkelf
I really dont know, but I always considered it as one due to the fact the foot does circle around the back and end in a delay.
But still its a dex so props on that!
John Alexander, 17
Calling all footbaggers from Kentucky if you see this sig and are from KY, PM ME!!!!
"Beggers cant be choosers"
"Yes and givers cant be asses"
www.myspace.com/coheed_dude
- Zeb Jackson
i think your just describing a regular atw that lands on an inside delay, all the inside delay does is make it stylie
(or atleast thats what i think your describing
-Zeb Jackson
http://www.elitefootbag.com
Yes this is a good area of your leg to be dexing with you dont want to be using your whole leg then your just trying to hard and will end up frustrating yourself, try using as little as possible to dex around the bag as its easier and allows you to see more of the bag for the catchjohnl583 wrote:When doing an atw do u dex around the middle of ur lower leg?
Toby Smith
First Comes Form Then Content
Each One Teach One
To Each Their Own
Each One Teach One
To Each Their Own
Help for Flipside
Ok. so i landed my first around the world on my (non-dominant) leg, aka my left leg... Im a righty.
and I was told by many players that I should learn everything on both sides at the same time...
i can do toe stalls and inside stalls on both legs perfectly, but I would like to learn clipper and ATW on my left leg as good as I can on my right (dominant) side...
Can anyone help:?:
Can anyone help:?:
"dominant"
Do a bunch of your strong ATWs in a row, and observe the way you're balancing before you go into it, the way your whole body moves when you're dexing, the speed of your dex, the place you catch, your posture at the end, and make sure you're copying all that with your flip side.
