whats up with this concept?
i got this description but..im not sure...its not an uptime set..right?
"Stomping" is a concept that involves planting both feet at once after setting the footbag, then executing the desired move. An example of this would be a "Stomping double leg-over" (Set -> Stomp -> Double leg-over).
Stomping
Stomping
well, with stomping DLO, you set from toe, replant your set foot, then jump into the first dex with both feet coming off the ground at the same time, and the legover following the mirage immediately. that's a stomping DLO. I'm not sure what other moves you could stomp. I'll try and show you one next time we play, or maybe you'll be able to show me.
- Pyroman924
In the last Online Competitions, I hit Butterfly>Far Osis>Far Stomping Dyno as my Novice Sick 3. I fyou have that video just check it out and that's stomping. Matt has the right written description, this is just if you want a visual.
Alan Underhill
http://www.myspace.com/pyroman924
"The more you drop, the better you get." -Ben Rinowski
Red hit stomping whirl a while ago, it looked pretty cool cuz you have to plant and then jump with both feet for the dex, and then catch it with only one foot.
Nick Landes
Proudly Representing Fourkast Footbag Co.
http://www.fourkast.com
Portland Blog
All the ladies love Matt Cross because Johnny Depp + Footbag = Matt Cross
Mastery is the combination of knowledge and practical experience
Portland Blog
