Inside Stall
- ToxicHippo
- Hack Fiend
Inside Stall
Inside Stall
SET > INSIDE [DEL]
http://www.hackrifice.com/minisooper/1insidedel.mpg
I need help on both inside stalls, and sole stalls. I have toe stalls on lock now, but i wanna learn more. Also, i can't get my ATW's around fast enough, but I'll get to that later.
SET > INSIDE [DEL]
Ben Harper- Graffiti Artist, Footbagger, Skateboarder, Musician.
Not Quite a Full Fledged Member of http://www.philly-footworks.com
- peanutbuterboy
Ok man listen up,
1) on your inside stalls its just like hitting in on the inside but when you go to hit it dont hit it, just go down on you support (planted) leg and sorta cradle it with the stalling foot. Check out some vids.
2) sole stall...I hate it...but if you want to learn stall it on you toe then set it up about at you torso i would say then then turn your body around on you planted foot (leave the foot your going to stall it on up) and bend you knee and get that foot flat like crazy flat and turn it over and go down on you planted foot. This one will take a lot of practice but if your dedicated you will get it.
But in the mean time while you are workin on those do your atw over and over. You think your not doing it fast enough but you can. What i found when i was doing it was i that i was kinda getting my leg to far from it. It needs to be short and sweet just barely are around it.
Good luck man and practice practice practice!
Luke Andrews
- JFootbagger
Yeah I agree with Chris on this one. You need to have toe and clipper down pretty, no ROCK solid. Try first alternating Toe stalls. Build up to where 50 is no challenge. While you're working on toe stalls, work on clippers. Now clippers can take sometime to get used to and is one of the most frustrating basic for new players. PRACTICE PRACTICE PRACTICE, and PRACTICE BOTHSIDES. You can find tips on how to do clippers around here somewhere. Keep up the hard work!
Jordan Wong
-Footblog! Check it out!
Enter My Mind
Enter My Mind
Guest
Yo Toxic ! This is what i do, on both sides and everyday : inside stall>same
toe>in to out dex ( pixie )>out to in dex ( fairy ) .
After i warmed up like that, i work on mirage/legover combos and then i move on to drilling clippers.
I think its a good drill for beginners like us, because it is improving coordi-
nation, controll and calmness. Before i drilled these "boring " basics, i could
hit pixie legover and smear, but very messily and not on command .
I also find this drill good, because it forces you to deal with the dreadded
goodside/flipside difference at an early stage.
Of course you wont need a 2add atw or an inside stall per se later on, but
IMO they are the foundation for all pixie/fairy set trix and you'll get in deep
shit trying to hit clippers, if you dont own the inside stall.
i hope that helps
i hope that helps
- Posi-Cole
While I agree that sole stalls aren't exactly necessary as a fundamental of footbag, I find it absurd advice to tell someone to not worry about learning an inside stall.Shredster wrote:I wouldn't worry terribly about inside and sole stalls...They aren't as important as clipper, toe.
We all know that footbag is about building a foundation, and making building blocks ... and what is the main component of a clipper? The inside delay! Seriously, everyone should learn how to have solid inside delays and then progress to learning clippers. If you can't do a solid inside delay in front of your support leg, how are you supposed to learn how to do it properly behind your support leg (clipper) ?
Maybe it's just me, but I say, learn inside delays, get your ankle flexibility up, and then learning clippers will be that much easier as you will only have to worry about the timing, as opposed to having to worry about the timing and having a flat enough ankle with enough cushioning to catch the bag.
Cole Hobson
True, but i find inside and clipper delay to be two completely different feelings...I could do an inside stall, but never a clipper. I personally found no advantage to clippers by practicing inside stalls. But that may just be me.and what is the main component of a clipper? The inside delay! Seriously, everyone should learn how to have solid inside delays and then progress to learning clippers. If you can't do a solid inside delay in front of your support leg, how are you supposed to learn how to do it properly behind your support leg (clipper) ?
I guess it was kind of not right to say not to worry about inside and sole stalls. Just becaues they aren't used often do not mean they aren't important.
Chris May
Word ! IMO, the inside stall is the root of a solid clipper,
just like, there wouldnt be much running, if one never
learned how to walk .
But of course, if one already owns the inside stall, then
its obsolete to keep practicing them, and one should go
drilling clippers, like sprinter should be working on sprints,
and not on his methods of walking
EASYKINKI
- JFootbagger
WOOT INSIDE DELAYS
Jordan Wong
Enter My Mind
Enter My Mind
MorgenAsche
PostPosted: Mon Jul 04, 2005 6:07 pm Post subject: clipper and inside stalls Reply with quote Edit/Delete this post Delete this post View IP address of poster
are there any stretches or things like that that you can do to get better at clippering or doing inside stalls
Back to top
enhancement
PostPosted: Tue Jul 05, 2005 4:12 am Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
When I started out I did my insides really high up, it made the foot flatter then slowly it just got lower. For clipper when I started out, I spent a whole 4 hours landing my foot to the ground. Then I started to land my foot just above the ground. It works great for me Laughing
_________________
Shane A. Smith
WASF Footbag Feature - Untitled
13 Minutes 20 Seconds Complete
Challenge Me
Back to top
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
BalinorNZ
PostPosted: Tue Jul 05, 2005 5:49 am Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
Basicly, if you want flat clippers do this:
1. Get your bag on an inside stall and lower it as close to the ground as you can (do NOT actually put it on the ground to make it flat) without it rolling off. Twist your ankle as hard as you can to do this.
2. Hold it like that for atleast 30 seconds then moves your stall round your support leg so your in a clipper (you will have to bend support leg to do this).
3. Hold it there for atleast 30 seconds twisting your ankle as much as you can. Then move the stall back round to an inside stall.
4. Repeat above.
You might need to hold on to a wall or something to keep balance when you first start off, but this will also improve your balance.
After like a week or 2 of doing that everynight you will have nice flexy ankles and then you just need to work on the timing and seting for clippers to get them down Smile.
_________________
Please Challenge Nic Bathgate
Entrys for the March 2006 online competitions are due 31st March! Submit them now to BalinorNZ@gmail.com!
Events: Open Sick1, Open Sick3, Novice Sick1, Novice Sick3.
Back to top
View user's profile Send private message Send e-mail Visit poster's website AIM Address MSN Messenger
ICQ Number
freestyler4life
PostPosted: Thu Jul 07, 2005 10:56 am Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
i did what balinor said and after you get comfortable doing that i would get a big and heavy book(like a dictionary)and do the same thing
_________________
Matt Coffman
Back to top
Uranos
PostPosted: Thu Jul 07, 2005 11:14 am Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
Yeah those stretches Nic said ar helpful when you are learning insides and clippers in the early stages. It even helps later in your game because you can use them to warm up.
HOwever i disagree that your clippers will become flatter as you do this. Sure, at the start it may alter the flatness by a bit, but these excercises are mainly done so your muscles will develop memory and strength to do clippers and insides. It won't neccessariliy make your ankles like Vasek's, although i wish it did Evil or Very Mad
Good luck with clippers and insides! Very Happy These are very essential to your game!
_________________
Alex Urano
Melbourne Footbag Club
Read my blog here:
http://www.modified.ca/footbag/viewtopic.php?t=11782
Back to top
enhancement
_________________
Shane A. Smith
Challenge Me
Back to top
BalinorNZ
4. Repeat above.
_________________
Back to top
ICQ Number
freestyler4life
_________________
Matt Coffman
Back to top
Uranos
_________________
Alex Urano
Read my blog here:
inside stall Problem.
Hi Guys.
when i want to make a inside stall the bag is always roling down.
i go in my legs and so how in this tutorial http://www.footbag.org/gallery/show/8532
i can toe stall but inside is so strong.
do you have tipps for me
http://www.modified.in/footbag/viewtopic.php?t=18792
I wrote this a few weeks ago and i think it is very helpful.
- Pancake Flogger
Joe Bielecki
- Hack Fiend
How to achieve more set height
I can't seem to set the bag very high after an inside stall or clipper stall. How would I achieve more height from my sets?
step 1: perform and hold the stall.
step 2: gain balance and relax. continue to hold the stall further.
step 3: bend the knee of your support leg and bring the stall closer to the ground.
step 4: straighten the support leg and push the bag upward with the stalling foot at the same time. To get a lot of height, you can even hop off the support leg just a little bit (this is how I get the right height and rhythm for ducking and spinning).
step 5a: hand catch and repeat.
step 5b (once you gain some strength): repeat.
Give that a try. Also, please consider changing your thread title to "How do I achieve a higher and more controlled set?" so that others know what the thread is about. The edit button is in the upper right hand corner of your post, an you can change the title that way in about 8 seconds.
