Miraging Symp Mirage (Merlin)
- Hack Fiend
SET > OP IN [DEX] > (NO PLANT WHILE) OP IN [BOD][DEX] > OP TOE [DEL]
when I'm trying toe Blur I can get the first Mirage in but when I try the 2nd mirage it always hits my knee or thigh. Am I doing my 2nd Mirage too fast or what?
Hope is the pain we feel that makes us try again
Nate Allison
Makers of The Godbox and SPeaker boxes.
ASH company. If interested PM me on here or on AOL @ HxCderelict or on Yahoo@ kingnothing42069.
Nate Allison
- Hack Fiend
I probably sound like an idiot but I can't hit Fear, Smear, Blur or Atom Smasher because I can't do Stepping or fairy sets as for the Atom Smasher never really tried it.
Nate Allison
Nate Allison
- Hack Fiend
I guess it's all downtime although I think it's uptime I was trying it by myself soo I have no other opion on this.
Nate Allison
Nate Allison
merlin - miraging symp mirage (the subject of this thread should be changed to this name from toe blur, as toe blur implies a different move)
let's say, hypothetically, that there is a footbag on your right toe.
set it straight up off your right foot to about your waist or belly button. as the bag is rising, plant your right foot as you raise your left knee. point your left knee in, and put all your weight on your right foot as you bend your right knee slightly so you can spring back from the bend for the second dex. at this point the bag should be peaking at your midsection, and your legs should be in position for the bag to fall past your left knee for the first mirage as you spring back off your right leg for the leggy symp mirage. Both dexes feel like they happen at about the same time. Continue to put your weight on your right side, as your right leg is going to be catching you. I don't have much to say about catching the bag. Try to keep your dexes tight and controlled so that the catch is as easy as possible, and remember not to set too high.
I hope these tips help you and anyone else trying to learn this move. If I was unclear, or if these tips helped you hit this trick, or if the tips weren't sufficient, please post here and say so.
- Paul Agostinelli
- Paul Agostinelli
This move is cake or the depending on how you hit it.
I can't do quantum jack, but I can hit the rest of what has been said and can tell you first hand its not like smear, fear, toe blur, or atom smasher. It's more like a flail or a symp mirage really. IMO anyways.
The first dex in this move isn't even hard. Concentrate all your effort on the second symp dex and get your stalling foot quickly back down after the second dex.
I find that the set should be about waist high. Lift your first dexing leg off the ground and jump for the second dex. The first dex is a formality and necessary in order to get that leg out of the way of the second dex. Leave it hanging in the air until the second dex has cleared and then whip it back under.
I have been trying a variation on this move, trying to snag a third dex with the stall foot at the end of the move. Like a merlin that ends in legover instead of toe stall. I am too large (20 pounds to go) and not quite fast enough to clean the last dex. But I bet Pinkus or Jordan or someone a bit more coordinated could do it.
Oh, and please feel free to contact Maraxus for details about how I shred and what I hit. My video representations are very rusty and I have lost another 5 pounds so my shred length and difficulty are starting to creep back into my game.
~peace
Damon
~peace
Damon
try doing the last dex symposium leggy. If you have champions league or fo shizza their is a run of peter Irish's where he starts with stepping voodoo, and if you notice the last dex is done leggy symposium.
"...You have to get, really, practice, like eight hours every day. Then you get good level and then you can compete....There is no money, so players are like big family and that is what I -like" -Vasek-
Reid Strellner
Reid Strellner
It is crucial if you want to get good at footbag that you learn Job's notation.
I would say that understanding what a move is, is probably the most important thing in learning how to hit it. Once you've learnt Job's, you will understand footbag moves a lot better. Usually there are no easy ways of getting better, but I think in this case there is. It probably only takes about 20 minutes to read through the tutorials for Job's notation at footbag.org and understand them.
- King Monkey
And to answer Psilocybe's question: Yes.
Put your name in your sig too, eh?
