Fairy/Shut-Spinning
TOE > SAME OUT [DEX] > BACKSPIN [BOD] >>
Can someone who is an expert on fairy spinning please give me a run down on how to do it well and any criticle advice that will help?
ie.
How high to set (I can duck my fairys)
When to start spinning
the exact stepping involved in say fariy spinning clipper
The best style for fairy spinning... leggy or hippy?
Should the set be jumped into?
Also I would like it if someone could answer me this questoin:
Do fairy spinning moves get pdx just as the spinning moves that get pdx do?
Thanks!
Fairy/Shut-Spinning
Re: Fairy Spinning...
Thanks!
what do you think?
James Randall
I just started doing this set. I try to rock out a hard hippy fairy set to about shoulder set, and just turn my back to it as it's rising (but not before it's left my foot).
If you can do a high fairy set, and you can spin, just keep practicing fairy gyro mirage. I would recommend against doing it leggy, that doesn't look so good unless you're trying to bust a gyro janiwalker afterwards. good luck, fairy spinning is super styley!
