Exitialis Provocator - Rory
And it goes a little something like this...
Tricksy: I can hit most two adds. I'm a strong tiltless player and I like the bothsided flow. Currently the guiltless string lengths are about 4-6 contacts and the tiltless can reach up to 20. Notables:
pixie: plo, smear, smudge, dimwalk, parkwalk, magellan
atomic: atomsmasher, legbeater, tap
stepping: ripwalk, stepping clipper, blur
spinning: spinning toe, ingyro mirage, spinning butterfly
ducking: ducking toe/butterfly/mirage/legover
I've also been working on some of the other downtime tricks: i.e whirl/swirl/osis/drifters/dlo , but have difficulty doing them in strings.
Rory "Tophat" Dawson
I did the full repeats.mosher wrote:SICK RORY!!!
for the rpt's did you do the full repeat and not just the combo on each side?
And Jeremy, you sir, are a slave driver. I was just checking modified as part of my post-session routine when I saw your challenge... Couldn't resist heading back down to the shredroom to give it a try. I can't remember how many times I got between 15-20 contacts before I just died on the floor. My best run was 25 contacts (started on a ducking toe and dropped on the flip ducking toe 24 contacts later!) ... I'll give this another go tommorow.
If I put just enough apple juice and water into sprite, I can make it taste like ginger ale.
smear>smudge>pixie pickup rpt -> Did one half of this on my flipside (dropped on strong smear )
Mirage > Ducking Butterfly > Pdx Mirage > (rpt) demolished! (you're fun to shred with too byrin! )
butterfly>stepping op legover>plo>rpt conquered!
40 tiltless (repeats and higher add moves allowed) CRUCIFIED!
I ended up getting 42 contacts! Although the string was about 1/3 legovers/far legovers and 1/3 mirages/clip set mirages. I did get my bsos ducking toes in there though! Gingerale time!
