2007 March Online Competitions - Official release
- shredzilla
For the record the video i recieved from Rory was called stepping-wauxpin.mov. I saw that he did it from a crazy toe set and called it toe stepping wauxspin (yea its spelled wrong) but i dont know enough about either wauxpins or butter rakes correctly distinguish between the two.Matt Cross wrote:it was a transcription error by the editor,
When i said i was at a loss for what to call it i meant that I personally had no idea what it was so i just went with how Rory had labeled it, but added the toe infront of stepping because i thought that was important.
It was labeled Brian Dennis,USA,Zoid Eggbeater.mov, sorry but i cant take resposibility for that one.brinard wrote:while were on the topic of mislabeld.....
my trick was zoid pdx egg... i labeled it right, but i guess it didnt get thru.
im pretty sure its right...
set from right xbd toe, then the next dex is my right leg first egg. if i had set it from clipper, itd be paradox...
hey,Matt Cross wrote:I ranked rory so low because I thought that he hit a different move than what he was attempting, or because he mislabeled it or something. I dunno, he lost "points" with me because of that little error, but I've just now read that it was a transcription error by the editor, not by rory. I'd like to change his rank from 8 to 4, and change the ranks from 4-14 or whatever it is accordingly. apologies. that really was a super cool move that he did. wauxpin would have been cooler but butter rake is sweet.
It was my error in naming the trick. I am not familiar with naming conventions around wauxpin and butterfly rakes. I thought butterfly rake was catching the bag xbd position and raking it through and wauxpin the same thing except catching the bag in non xbd position.
Anyways, what I was going for was a toe to toe "ripwalk" type move, basically a quasi rewind of my toe stepping set. I can't do delays very well in dragon toe (or whatever that position is called) and so I thought it would be cool to spin 180 degrees to catch the bag on my toe in front of my support leg (not xbd or behind me). If you watch the clip in reverse it kind of looks like a pendolous set except with no pendulum and the bag set from in front of the body. I was under the impression that rakes needed to be scooped from behind the body?
I talked to Kevin to get his opinion on what the second half the trick actually was and he also thought it was a butterfly rake. I tried doing the "rake" without a butterfly component and without scooping the bag... and it felt more like a gyro toe... or something, but it couldn't be gyro or spinning because I jumped over the bag and spun 180 deg as I jumped. Is there a name for this kind of spinning?
I don't really care about what my ranking turns out to be. I hit the trick exactly as I envisioned it in my mind and that is what is important to me. I would however like clarification on the difference between wauxpin and rake, and xbd rake. (pm me)
Rory "Tophat" Dawson
...brinard wrote:i labeled it right, but i guess it didnt get thru.
brinard wrote:so heres my sick one entry. i think it counts as a zoid set egg, but i havent seen a zoid set... so i just did what i thought counts as zoid.
i think its a 5 add. [rooted][crossbody] toe set> same out [dex] >op out[dex]>same toe [delay]
thanks, and goodluck on your comp.
Sorry I didnt have time to watch the entrys at the time of downloading them, I would have corrected the error if I did. I assumed you hit zoid ss eggbeater because of the jobs in the above email not including pdx.
- Iron Clad Ben
- Superior Precision Bionics
- Zac Miley
I meant my sick 3.Iron Clad Ben wrote:It may have been the video quality/framerate but I thought the flux was the. You rotated into the osis before illusion dex was complete. At least that's what it looked like to me.Isilwar wrote:Can you please give a reason? I like reading critiques on my game.B_Man wrote:Open Sick 3
9. Zac
I don't think my sick 1 was the at all. Thin probably, but not the.
i'm the one of the judges and that's my rankning for open sick 3 and open sick 1 comp.
In the evening i'll update the rankings - i mean i will judge novice competitons.
Open Sick 1:
1. Jorden Moir - surging flux
2. Gray Chadwick - ducking pdx symposium eggbeater
3. nic bathgate - fairy duck whirl
4. Mathieu Gauthier - spinning motion (not well done hand catch)
5.Pete Bowler - whirlygig (it's slurry a bit)
6. Brian Dennis - zoid pdx egg
7. Jeremy masselis - spinning pdx egg (the dex was thin and the delay was bad)
8. Cody Carter - dbl spin clip
9. Rory Dawson - toe stepping far butterfly rake
10. Micheal Perny - fog
11. John Fanuzzi - pixie dyno
12. Toby Suggate - pixie dod
13. Kyle Morley - blurry dada (slurry and dada was pretty the)
14. Zac Miley - pixie flux (for me there was no illusion)
Open Sick 3:
1.st Kevin Regamy
Symp atomic DLO - sailing ss eggbeater - pixie ducking symp eggbeater
Cleanless: 4 points
Hardless of tricks: 6+6+7
Hardless of links: Frontside Predator - sailing ss eggbeater (1) - pixie ducking symposium eggbeater (2)
3 points
variety symp (1) atomic (1) xdex(1) miraging (1) illusioning (1) - pixie (1) atomic (1) illusioning (1) illusioning (0) - pixie (0) ducking (1) symposium (1) illusioning (0) illusioning (0)
19*0,35+4*0,15+3*0,35+10*0,15 = 6,65+0,6+1,05+1,5 = 9,8 points !
2nd. Jorden Moir
alpine blurry whirl > beta bed > ducking dolomite
Cleanless: 4 points
Hardless of tricks: 6-7-6
Hardless of links: alpine blurry whirl - beta bedwetter (1) beta bedwetter - ducking dolomite (1)
2 points
variety: stepping (1) ducking (1) pdx (1) whirling (1) - stepping (1) pdx (1) symposium (1) illusioning (1) illusioning (1) - ducking (1) - symposium (0) dex (1) dex (1)
4*0,15+19*0,35+2*0,35+12*0,15=0,6+6,65+0,7+1,8 = 9.75 points !
3rd Nic Bathgate
fairy ss dlo - fairy ducking butterfly - spinning pdx whirl
Cleanless: 4 points
Hardless of tricks: 4+5+5 = 14 points
Hardless of links: fairy ss dlo - fairy ducking butterfly - (1); fairy ducking butterfly - spinning pdx whirl (1)
2 points
variety: fairy (1) miraging (1) legover (1) - fairy (1) ducking(1) whirling (1) - spinning (1) pdx (1) whirling (1)
2*0,35+14*0,35+4*0,15+9*0,15 = 0,7+4,9+0,6+1,35 = 7.55 points! (less 0.35 than last entry which i judge)
4th. Jeremy Masselis
matador > ripwalk > pdx egg
Cleanless: 4 points
Hardless of tricks: 5-4-5
Hardless of links:matador - ripwalk (1) ripwalk - pdx eggbeater (0)
1 point
variety: pdx (1) atomic (1) butterflying (1) - stepping (1) butterflying (1) - pdx (1) illsuioning (1) illusioning (1)
4*0,15+14*0,35+1*0,35+8*0,15=0,6+4,9+0,35+1,2 = 7.2 points !
5th. Mathieu Gauthier
Phoenix - spinning osis - far motion
Cleanless: 4 points
Hardless of links: phoenix - spinning osis (1) spinning osis - far motion (0)
1 point
variety: Pixie (1) ducking (1) butterflying (1) - spinning (1) spinning (1) - dex (1) dex (1) spinning (1)
4*0,15+14*0,35+1*0,35+8*0,15=0,6+4,9+0,35+1,2 = 7.05 points !
6th. Tobbu Suggate
phoenix - pdx whirl > ddd -
Cleanless: 4 points
Hardless of tricks: 5-4-4
Hardless of links:phoenix - pdx whirl (0) pdx whirl - ddd (0)
0 point
variety: Pixie (1) ducking (1) butterflying (1) - pdx (1) whirling (1) - dex (1) dex (1)
4*0,15+13*0,35+0*0,35+7*0,15=0,6+4,55+0+1,05 = 6.2 points
7th. Julien Romiti
fairy osis > torque > dlo
Cleanless: 4 points
Hardless of tricks: 4-4-3
Hardless of links: fairy ss osis - torque (0) torque 0 dlo (0)
0 point
variety: fairy (1) spinning(1) - miraging (1) spinning (0) - miraging (0) illsuioning (1)
4*0,15+11*0,35+0*0,35+4*0,15=0,6+3,85+0,35+0,6 = 5.4 points !
8th. Brian Dennis (i changed brian sick, because there are 4 tricks IMO)
- fairy butter > blizzard > toe walkover
Cleanless: 4 points
Hardless of tricks: 4-4-1
Hardless of links: fairy butterfly - blizzard (1) blizzard - toe walkover (0)
1 point
variety: fairy (1) butterflying (1) - stepping (1) illusioning (1) - (0)
4*0,15+9*0,35+1*0,35+4*0,15=0,6+3,15+0,35+0,6 = 4.7 points !
EDIT: i've made one mistake, but i've just corrected the thing.
Open Sick 1:
Open Sick 3:
1.st Kevin Regamy
Cleanless: 4 points
3 points
2nd. Jorden Moir
Cleanless: 4 points
2 points
3rd Nic Bathgate
Cleanless: 4 points
2 points
Cleanless: 4 points
1 point
Cleanless: 4 points
1 point
6th. Tobbu Suggate
Cleanless: 4 points
0 point
7th. Julien Romiti
Cleanless: 4 points
0 point
Cleanless: 4 points
1 point
Kamil Hucal
It was a toss up between you and Brian for 9th. Everything of yours looked good, except I thought the Paradon was 'the'. Had it looked good, you would have had a 8th no problem.Isilwar wrote:Can you please give a reason? I like reading critiques on my game.B_Man wrote:Open Sick 3
9. Zac
- Byrin Wylie
ShrEdmonton
ShrEdmonton
First time i "judge", don't blame me
(and maybe sorry for my english)
Novice sick 1
1-Julien R.-Smog : Nice triple dex man! All the dex looks good. Props !Next time in open
2-Benjamin B.-Pdx dlo : Looks very clean and easy. Props.
3-Alan U.-Toe ducking whirl : Nice move! Dex looks ok but duck is a little bit too high.Go for tomawak now
4-Carlos B.-Diving mirage:Original trick , dex and duck are ok, but it could be "smoother".
5-Benjamin M. -Double atw : looks easy, but not such original.
6-Matt H. - Dimwalk : pixie could be cleaner . Try to do it higher to have the time to do your butterfly easily. The trick will look "smoother".
Novice sick 3 (it was hard to give a first place)
1-Michael P.- drifter>pdx drifter>torque : Such cool links! Looks very controled. Props
2-Cody C. -Atomic legover>Tapdown>spinning but : Nice atomic>atomic . Looks cool but i prefer michael's combo. Want to see your other atomic.
3-Alan U. - Far osis>infinity>far stomping dyno. Sweet dude. Far stomping dyno looks cool .Props on both osis. Infinity looks too easy man, you should find an other trick.
4-Benjamin B. - Ripwalk>Dlo>Symp pixie . Nice use of both clippers and toes. Everything looks clean.Props
5-Carlos B. - Ducking clip>pdx mirage>rake : Rakes are always style dude! Could be more controlled but it's ok
6-Kyle M. - Blur>butt>diving osis . Your stepping was pretty the. Diving osis was pretty cool.
7-Benjamin M. -Symp mirage>clipper>ducking clipper(>osis) : Too bad for the clipper. For the duck, think it more like it's your head which have to turn around the bag, and not the bag around your head.
8-Matt H. -Mirage>butterfly>osis : Nice! Now drill its baby!
Novice sick 1
Jeremy Masselis
Shred addict !
Shred addict !
Wow! Nice comps this quarter
Open Sick 1
1. Jorden
2. Rory - that was exactly what it said. Toe Stepping Wauxpin i think . That wasnt a butterfly rake at all. Sick rory!
3. Gray
4. Jeremy
5. Nic
6. Mathieu
7. Brian
8. Toby
9. Michael
10. Cody
11. Zac
Open Sick 1
1. Jorden
3. Gray
4. Jeremy
5. Nic
6. Mathieu
7. Brian
8. Toby
9. Michael
10. Cody
11. Zac
