Reverse Paradon? Non whirl dexes
Has anyone hit reverse paradon, with non whirling dexes? I think to hit it you would essentially have to do 2.5 dexes to get your leg out of the way for the clipper.
toe>op in[DEX]>same in [DEX]>op clip[XBOD][DEL]
has anyone hit this? if so whats the name
this is not whirr, i have done it with an "air bag" and you can do it without whirling dexes.
I do my whirls like my paradons...
you don't want to tell me I'm doing pdx reverse whirrs all the time.
when do you think a whirl seperates itself from leggy miraging ? (afaik whirling IS leggy miraging, the same way paradons are leggy reverse mirages (aka illusioning). Just because you tend to do whirls more far away from your body or in a strange angle, they do not become something different than leggy miraging ss clips)
-Richard Vock-
"And today the great Yertle, The Marvelous he,
Is King of the Mud. That is all he can see.
And the turtles, of course...all turtles are free
As turtles and, maybe, all creatures should be."
- Dr. Seuss
- Dr. Seuss
It's okay, Henry. At least I know what you're talking about. It's definately possible completely downtime and nothing like a whirl. It would probably be easier to non-whirl when done symposium. I don't do barrages much because I the them, but my toe barrage is clean and I don't do any of that fake barrage (whirling....) crap ;p
- Sporatical_Distractions
- registered sacks offender
i have messed around with a move similar to this one and have made contact downtime and non whirl. It was more like a reverse down double down then a reverse paradon. But i also think about it more as just using your utmost speed then anything else so it was probably sloppy as hell, but I know for a fact that if it is possible from a clipper then it is possible from toe.
Re: Reverse Paradon? Non whirl dexes
Those were some seriously non-whirling dexes!!!
The only problem is that the jobs doesn't match the video. It would be considerably harder to hit the dexes hippy if it was set from op toe.HenryG wrote:toe>op in[DEX]>same in [DEX]>op clip[XBOD][DEL]
Yeah - well the terraging ss clipper I guess is what you actually hit - but the second dex is below your foot. - but then you work well with the third dex and have lots of time. I think if you were just going for terraging clipper rather than bailing out of triple atw you'd find it easy to clean - judging by the time you have on the move.
- ShredOnLawn
