Blurry Barroque ????
Paulo Castro
Look, I hope you can hit it clean, but if you pause the video on the last dex on the first one, it's easy to tell that it's the, and on the second I can't see where the bag is at all, but I note that with the third dex your leg is at it's highest, so it keeps going up higher off the ground than for the second dex, so if you're dexing the second dex around your ankle, which is what it looks like, and the bag is moving downwards, which is pretty likely, then it seems hard to imagine that the move is clean.
Of course it's a super hard move, and upmost respect to you for being able to get as close as you can, if it is the, and I really can't tell in the second, I'd need to see a higher resolution version to be able to tell, so maybe it is clean, but at the same time, my opinion on the moves, and this especially applies to my own moves, is that if you hit something "the" that's the same as dropping.
I'm sure it's a crazy hard move, and all respect to you, I have never tried it because I think it's way above my abilities, but every time I've seen it hit on video, it's either been "the" or it's been like the second video you posted, and been impossible to tell if it's clean or not. Certainly well over 50% of baroques Vasek hits on video are the, let alone pdx or harder versions.
- Sporatical_Distractions
- registered sacks offender
hacksterbator
- Washed-Up Child Star
- mikeanello
I have never liked baroque due to its tendency to be "the". When I first saw baroque in vasek2.wmv - the video that shares footage with vasek2wide.wmv - I thought the move was simply a flashy crowd pleaser and not to be taken seriously.
Good work Milan on blurry baroque. You are certainly closer to getting it right than most video examples I have seen from other players. Keep up the good work.
Peace.
Peace.
Mike Anello
http://www.rochesterfootbag.com
Never give up, unless up is what the customer really wants.
hacksterbator
- mikeanello
True.hacksterbator wrote:isn't that pretty much freestyle's evolution in a nut shell?mikeanello wrote:I thought the move was simply a flashy crowd pleaser and not to be taken seriously.
Mike Anello
