Wich Bag?
Wich Bag?
Hmm.. I'm pretty new at footbag, the bag i use is a self stitched bag, and now i got lots of money..
I consider buying to bags, the Abshire and the sandman..
I heard the Sandman is best for newbie's but is that just because its cheap..
Wich one shall i buy, HELP ME!
Ehm or.. should i buy something else..
- SmellMyFinger
- Shredalicious
- 420FootBager
honestly I think the best thing a newbie can do is get a half decent crochet piece of crap and learn the basics with that. That is all hits, stalls, and the clipper with it.
By forcing your self to learn the basics with a crochet piece you set your basics very strongly and when you finally get a good bag you will pull your moves much more sharply and easly...
This is what I did BTW. Now I got a Mr. Sandbag which I am VERY happy with.
Gus P.-- Get'um up against the wall
Who let all this riff raff into the room
There's one smoking a joint and
Another with spots
If I had my way I'd have all of you shot
Another with spots
That's pretty solid advice. This would help enforce the very basics: kicks, toe delays, inside delays, (more or less) outside delays, and clippers. Once those are learned, I'd suggest going to a sandman or two so you can start landing the basic tricks: ATW both ways, legover, pickup, mirage, illusion, pixie, and farie. Keep working with it, then you can work up to an 32 panel stiched bag for more accurate sets and dialing in tricks. It's up to you what you want to do, but this should provide sort of an outline.420FootBager wrote:honestly I think the best thing a newbie can do is get a half decent crochet piece of crap and learn the basics with that. That is all hits, stalls, and the clipper with it.
Also, if you start with a crocheted bag, you may have to drain it a little... thsoe things often start huge.
John D
- RevertShredda
- Hack Fiend
I would also agree that this is good advise, however not for you. You have already "forced" yourself to learn all the basics with a crappy bag (sorry for saying that your bag you made is crappy, but it probably is, however I am VERY proud that you made your own bag).420FootBager wrote:honestly I think the best thing a newbie can do is get a half decent crochet piece of crap and learn the basics with that. That is all hits, stalls, and the clipper with it.
I would go for an abshire, carol, felix, or any other awesome 32 panel bag.
I started with a sandman, and I just recently got an abshire. I like playing with the abshire, because it isn't broken in. This way everything I do has to be extra good to keep the bag from rolling. I guess it's the same concept as 420footbagger spoke of. Eventually, when I'm better, the bag will be broken in as well.
Marc Reinecker
Can you imagine how nicely it would be broken in after Vasek using it for a day though?mouseman wrote:try get a felix bag and hope you're lucky, vasek played the euros final routine with one day old felixbag, I think that's enough advertisement for everyone.
It would feel like a month old bag
Hopefully back one day.
Jesse Malouf
Jesse Malouf
