So long as they do not violate patient doctor confidentiality - we will take a quick tour of the medical facility follow me please she turned on her heel and marched towards the facility,
Thanks Bobbee Neil Fred,Jude,Riaz,Bops,Santosh,Inder,Axx,Manjur,Vedan,Gavin,Yaj,Bobby,Apoo,Saiki,Mahaseerhan And others Your good wishes and get well messages are most heart warming and very though
until the body begins to accumulate the unmitigated death energy (karma) of the animals, and then animal experiments he conducted, chlorine caused required by every body cell. It is
of autoantibody response to topoisomerase pressed in SCN and retina, forms a complex fied kinases activates both the association
krys fantasy superbowl
andrew milligan
- Paul Agostinelli
well, first things first, is legover the only trick you can do both sides? if so then the only thing you should work on is getting the rest of those tricks both sided
most drills use the same trick on both sides
for instance a drill i practice a lot is
mirage>pixie>mirage>pixie
the first mirage and pixie are set from one foot, and the other two are set from the other.
I also recommend working on being able to do at least 10 or 15 back to back inside stalls
If any of the more experienced shredders out there want to contradict me or extrapolate please do
hope this helps
~NEL~
hope this helps
~NEL~
Atw>Mirage>Pixie>Illusion Rpt
Mirage>Leogver Rpt
Illusion>Pickup Rpt
Fairy>ATW Rpt
Try and set goals with yourself. Kinda have a 'contest' with yourself everytime you shred increasing the amount of repetitions of each drill. And remember to repeat each drill helping to improve BOTH SIDES!
Hope it helps and we'll shred again soon
Mirage>Leogver Rpt
Illusion>Pickup Rpt
Fairy>ATW Rpt
Thomas Smyth
My footblog http://www.modified.ca/footbag/viewtopic.php?t=8406
Challenge me! http://www.modified.ca/footbag/viewtopi ... 468#134468
