Double Legover/Mixer (DLO)
SET > OP IN [DEX] > OP OUT [DEX] > SAME TOE [DEL]
http://www.hackrifice.com/moves/3dlo.wmv
toe set just below waist high. Plant the setting foot as fast as you can while maintaining body control. Lift the first dexing leg into mirage position as soon as your setting leg hits the ground and then jump hard off of the planted leg. With your second dex leg (the one off which you jump), lead with your heel as you do a legover and scoop the bag up.
Thats all I got.
Thats all I got.
Try to keep your legs close together as well and try and keep facing in the same direction - rather than twisting around at all. This is a style thing - it is easier if you spin a little away from the bag but in my opinion it isn't as clean.
Also drill symple legovers - this will help for dlo a lot! Da da curve might also help but make sure your last dex is clean.
- King Monkey
i like to keep my shit tight, B.
by that i mean trying to maybe put tension in your leg muscles as you are doing the dexes in order to bring your legs up higher and make the move feel a bit tighter and crisper perhaps
im not sure if i actually do it right but it would be nice
I just think about the legover and throw my first leg over without even thinking about. Set, spot the bag, and now leading with the miraging leg but not even thinking about it focus on getting the second leg over and under.
[quotec29ccd4="zachatree"]my mirages are awsome, my legovers are great, but still i cant seem to do it, both dexs are fine but my legover always just misses the bag ARGGG[/quotec29ccd4]
Do what jeremy says and practice those symple legovers. They are harder to catch than regular legovers, and in dlo it is a symple legover.
Edit: Jesus this shit is all fucked up... Are you guys getting invaded? Christ.
Always Shreddin
James Erickson
Eugene Footbag Association (Orton, Nasty, Me)
w/ new additions (Casey, Alex, Eddie, and Shawnell)
James Erickson
I really think the key to hitting your FIRST FEW of ANY trick is to MINIMIZE THE TIME SPENT ON THE SET. Meaning: set the bag from toe as quickly as you can while keeping it accurate. Toe set up and bring that shiznit down as fast as you can. BEFORE the bag even reaches its peak, you should be starting your dexing for the dlo! I guarantee that if you try this and exectue the quick set correctly, you will hit DLO in your next session.
- Iron Clad Ben
- Superior Precision Bionics
Are both dexes uptime in the DLO or is it only the first one? I can hit legovers BSOS in my sleep and my mirages are coming along nicely. I want to learn to DLO after seeing Shredzilla hit it from a clipper set in the Novice Sick 3 this month. Should I work on Symposium mirage first? Double dexes just seem impossible to me at this point.
DLO & Eggbeater trick tutorial
http://www.footbag.org/media/908/AnzTri ... beater.wmv
edit: talking about the wrong move entirely hereIron Clad Ben wrote:Are both dexes uptime in the DLO or is it only the first one? I can hit legovers BSOS in my sleep and my mirages are coming along nicely. I want to learn to DLO after seeing Shredzilla hit it from a clipper set in the Novice Sick 3 this month. Should I work on Symposium mirage first? Double dexes just seem impossible to me at this point.
No it's not. Sailing is Pixie Atomic, DLO is Miraging Legover.janis wrote:If both dexes are uptime then thats sailing set, which is much harder than having the second dex downtime.Iron Clad Ben wrote:Are both dexes uptime in the DLO or is it only the first one? I can hit legovers BSOS in my sleep and my mirages are coming along nicely. I want to learn to DLO after seeing Shredzilla hit it from a clipper set in the Novice Sick 3 this month. Should I work on Symposium mirage first? Double dexes just seem impossible to me at this point.
In DLO both dexes are downtime, or the first one may be more peaktime, but there's no uptime dex.
Crispy DLO from clipper is Stepping far Legover, from toe it's Quantum op Legover.
Lauri Jaakkola
