technique: lifting bag from ground
Sounds so funny... - but have you guys ever noticed that when you are skooling some trick that you drop all the time. When you have dropped it 30th time your back is hurting like hell when you pick it up once more.
I know you guys have too much free time, so somebody must have done some research about best techniques for lifting the bag (with your hands) from the ground without getting your back hurt.
Any ideas?
My advice would be keeping your back strainght and bending your knees.
Any ideas?
I think people are too anti-foot-pickup. Especially when it comes to skooling a move/combo over and over again like you said, it's bothersome and tiring to bend over every 5 seconds.
Of course, the one-foot technique where you scrape the bag against the ground and try and scoop it up is totally unacceptable, but I can roll it onto my toe with my opposite foot just as gently as picking it up with my hand. That probably puts less wear on the bag than even kicking it a few times.
And I'd trust any experienced freestyler to properly pick up my brand new felix bag. It wouldn't bother me one bit. (but of course I wouldn't do that to someone else's bag, for fear of getting my head bitten off)
chris dean
junkyardjew
i sort of like bending at the waist to pick up my bags. up until, well, the week after i started playing footbag i guess, i couldn't touch my toes. not even close. the fact that i can now reach the ground to pick up a footbag without bending my knees still has a lot of novelty value to me. plus, it stretches out my legs and back while i'm playing (i have chronic back tension, which is why i couldn't touch my toes before).
Jared MacKay
At many maritime amusement parks, like seaworld, they sell these sticks which are about 2 feet long, which have a small plastic shark at one end, and a pulley mechanism at the other. When you pull the trigger/lever on one end, the shark closes his mouth on the other end. In the movie ET, Elliot has one, and he uses it to scare his fish. Anyway, I think you could use one of those to pick up a footbag off the ground without bending over.
Alternately, I have a method of picking up the bag without damaging it using my feet. I stand over the bag, with my heels touching, but my toes at a 40 degree angle pointing away from each other. I grab the bag between my heels, and then quickly stand on my toes, which pops the bag in the air. Then I quickly toe stall beneath it. Anybody who has played with me has probably seen me do this... I should try and get a video up. until then, you should use the shark-stick method. Good luck.
ken, would a stick with a lobster claw at the end also work? I dont have one with a shark.
- peanutbuterboy
end of story for you back pain people.peanutbuterboy wrote:bend at the knees.
I've recently instituted a "no using your feet to pick up my bags" rule. Felix mentioned something about it at Chilly Philly, saying he felt it's really bad for bags, and shortens their life span. I just want my bags to last for as long as possible, and if that means bending over, or squatting at the knees
brian relly
- fan-tas-tic
- mosher
- brutal footbag cronie
Today I took a shot at the technique that Ken posted, it is SO frigging cool!!
It is touchy to get right, but when done with finesse you can pop the bag up from your heels right to your toe and into a string!
You HAVE to give it a shot.
Pinch it with your heels and pop up onto your toes and let go. Then all you have to do is catch it on your toe.
Thanks for the sharing your smooth moves Ken!
I prefer to roll my footbags onto my toe. that being said i try to avoid that on my only bag that is decent, it is an abshire that is weathered, worn and torn and patched too. Mr suderman has made me a deal, i take care of the bag and keep it for big sessions (GLASS!!!) and he will give me a suderag to replace it.
Adam Czarnata
-Parkin cars on footbags since '04
My back AND knees are screwed. Repetative deep bends with either end my session. I roll my abshire (which has been in use for almost a year now) onto my foot with my other foot. It's gentler than when I kneed the bag in my hands (which I do constantly, it's a habit).Matt Cross wrote:end of story for you back pain people.peanutbuterboy wrote:bend at the knees.
I've recently instituted a "no using your feet to pick up my bags" rule. Felix mentioned something about it at Chilly Philly, saying he felt it's really bad for bags, and shortens their life span...
On a related note, I NEVER use the bag on rough playing surfaces. I think that kills bags way faster than my toe pickups do.
EDIT: I thought I'd point out: The method I use for picking up the bag actually IS damaging to bags that use sand as filler, but the damage to pellet filled bags is minimal. This is because you use your feet squeezing the bag on itself to lift it, and the sharp sand is able to wear away on the panels, but the round pellets do not.
Colin Kennedy
ckennedy@footbag.org
Ah poop. Tom will hate me then, because half the time I roll the bag on my foot
The other half I usually pick up with my hands. When I do that, I usually bend my legs a little bit whilst bending at the waist to pick it up. Not the best technique, but it works.
I want to try Ken's method now
- Byrin Wylie
ShrEdmonton
ShrEdmonton
- JFootbagger
a cool nifty way to do it is pick it up with your heals than rake it with your toe and fling it up...Mike Park does it, it's pretty neato
Jordan Wong
basics=tricks=strings=people dropping their jaw in amazement
-Footblog! Check it out!
Enter My Mind
Enter My Mind
someone used to say in their signature,
"before you read what I wrote, just be aware that I read half your post at most. I may seem misinformed, or be discussing something entirely off-topic, but this is a small price to pay for not having to read your whole post."
or something like that.
See, when I think "toe pickups", I think spatching. As in, swinging your foot down towards the bag, rolling/scraping it quickly along the ground so that it pops up on to your toe. Hacky Sackers do this a lot with crocheted bags.
I toe pickup constantly, but I like to think I do it respectfully. I put on foot next to the bag on the ground, bring my other foot next to it so that the bag is held in between, then roll it up on to my toe. I don't know, to me, it doesn't seem any different than kneading a bag in your hand. I never even thought of it as harmful or bad-form.
In fact, I remember at worlds, on the first balcony in the Rialto Theatre, I was playing with Cole's bag, and he said, "Whoa Kevin, easy on the toe pickups, eh?" I was like, "Oh. Sorry." It hadn't even occured to me that THAT was an ever-dreaded toe pickup.
Fuck, I'm at work and the air-conditioning just came on. I'm freezing now.
Alternatively, when I'm practicing/drilling, I have about a dozen bags at my disposal...whenever I drop, I just drop another bag to my foot and try again. Once all the bags are on the ground, I only once bend down to pick up twelve drops.
- Kevin R.
F = G*((m1*m2)/r^2)
Know thy enemy.
F = G*((m1*m2)/r^2)
Know thy enemy.
