Pixie/Open
- shred_4_jesus
Pixie, Fairy
AHHHHH!!!!!!!!!! I need major help. I don't have anyone to kick with so many tips, would be greatly appreciated on how to do the pixie and fairy sets. any uptime components really.
Darin Thompson
"I am the way the truth and the life..."
--- Jesus
--- Jesus
- shred_4_jesus
- Avenging Disco Godfather
Take with a few grains of salt, I'm hardly an expert, and can only comment on pixie set since I have no fairy set:
How are your pixies & in>out atws? Really consistent, with a deep dex? If not, I'd work on these first. Naturally, you're dexing is going to get more consistent, quicker, and more efficient if you school basic dexes until you can do them on command.
So once that step is out of the way, I'd suggest concentrating on setting, then dexing, instead of trying to do it all in one continuous motion. In other words, make sure the bag is off your foot before beginning the dex, instead of pushing the bag off your foot when you start the dex.
Push off with your support leg when you're setting.
I'd also say that a person can have good form, or pretty good form, but still not get the dex uptime/ have enough downtime to feel comfortable going for a downtime component. If this is the case, you're on the right track, you just need to keep practicing the motion until its more fluid & feels less awkward. And then focus on giving a little push with your support leg, and you'll have the consistence & height that you need.
Playing with people definitely helps, too.
How are your downtime components?
Pixie Help
Ok well I know this is akward but pixie is the first trick im learning it is the one that came easiets to me but I have just tried to learn it a few days ago and have been proggesing but when i flick it off my to to do the dex it is not the high it is only about a foot off the ground is that bad should i make it go Higher
Re: Pixie Help
I have a few tips;axelmagic wrote:Ok well I know this is akward but pixie is the first trick im learning it is the one that came easiets to me but I have just tried to learn it a few days ago and have been proggesing but when i flick it off my to to do the dex it is not the high it is only about a foot off the ground is that bad should i make it go Higher
1. Stay in school, and practice your English skills. The aim of language is communication, and the better you are at communicating the easier it is for people to help you.
2. I'm presuming you're talking about a normal pixie; toe>same in>op toe because you say this your first trick. It is bad if you can only set the bag a foot high. I would work on not doing the dex at all, and practising alternating toe stalls; left foot to right foot to left foot etc. Aim to have the bag at about waist height every time and going straight up and down.
3. You talk about "flicking" the bag up. Instead of flicking it up off your foot, keep your toes pulled up so that you maintain a flat surface on your toe and lift your knee up while keeping your shin perpendicular to the ground. This should result in better height from the set and more control.
Good luck
I don't know what my promblems is. I thinks the bag keeps getting stuck in my toe walls. Should I cut them out? I try to set the bag then do the Pixie. But the bag keeps fly out. I need to learn Pixie sets. I have a uptime legover. But that is it. I really want to start hitting some new uptime stuff. But it is just not coming to me. This sucks.....
My girlfriend thinks I'm a dork.............
But she loves me anyways.
"Guydro F. Hydro"
Guy Herndon
richardabshire wrote: There is only a handful of people on this planet that actually shred. The rest are only spectators.
"Guydro F. Hydro"
Guy Herndon
- shredzilla
Yeah unfortunately pixie's one of those "drill it til it clicks" concepts. I struggled for a long time with that one and then one day I could just do them with no effort.
It's basically like doing a toe set, but midway through the set you throw your calf over it as it comes up. It's just practice and watch people do it in videos in slow-mo.
Your toe walls aren't the problem. If you're doing sets correctly, the bag should not spin when it's set nor should it roll on your foot. Make sure you set the bag before dexing it.
Ben Skaggs
Amateurs practice until they can get it right.
Professionals practice until they can't get it wrong.
No, I don't play soccer. Yes, there are competitions. 4 years. Lots of practice.
i heard that you should keep you walls on until you can drill the pixie, or else i heard otherwise, which is true?
My strongside pixie is godly, i can do it midstring sometimes accidently, but my flipside is like 25%. Sometimes it'll click and i'll do the right thing (and can never repeat that), but most of the time, it'll get caught in my calf. I know what i'm doing wrong there, bag is too far when setting, but then sometimes i'll hit me in the stomach..
Why does it hit me in the stomach, when it does it feels like i did it right but i'm setting weird still...
any help?
any help?
- shredzilla
Toe walls don't matter one way or the other. The only reason they're even there is to just create a bigger catching surface. They also help during your first month for gaining confidence catching legovers, mirages, etc. Once you reach a certain level, the bag will rarely even touch the sides of the walls. Although some people believe keeping them on helps you learn to not do pixies the wrong way. I don't agree with that, I think you know you're doing it wrong regardless if it catches in the wall or flies off the side.
You can cut em off or keep em, it's an aesthetic preference. I like to keep mine on cuz I love the way lavers look, they just have a really classic look about them.
You sound like you're doing it right, you just need to keep drilling it. It just kinda happens one day. I don't know what else to say, but that's the way it works. One thing I do try to focus on is keeping my foot as straight as possible during the first part of the set. Like don't let it flounder around on the way up before the dex.
haha, today i was hitting smears, smudges and PLOs midstring, only strongside though
well, i already took off my walls so at least it doesn't matter. i took them off because people (non-footbaggers) were like dude ur shoes are cheap!!
i kinda know what you mean now, about just getting it all of a sudden. i think it's also building up the muscles and balance in the support leg too. i am going to practice my atws alot for the next little bit to see if that helps.
i find it really hard to "air" bag a pixie, for form purposes.
If it's hitting you in the stomach, it seems like you are trying too hard. Set easy. If you're doing it right it shouldn't require much effort.
Ben Skaggs
- capuchino man
- shredzilla
- Benjaminzors
