Monster
- skoxn
Monster
can someone please explain, what exactly this is??
i´ve seen it first on gfo 05 in berlin and some days ago, jorden did it in his last video.
i don´t get the technique, it´s something like an inside set stall-thingy...?!
- max
- Australofrenchbrityorkus
I think monster is just a spinning inside stall. But I could be wrong. There are a lot of Jorden's tricks that are "monster variations" and that end with a spinning inside such as symposium swirling spinning inside. Now maybe monster is all of this or just the end bit of the move. i'm not sure, but my bet goes on spinning inside stall.
Maxime Boucoiran
French ConneXion
BFC
French ConneXion
BFC
Monster stall was invented by Kenny Shults. It's an inside surface delay in a forward position with the upper body twisted away from the footbag, looking over the same shoulder relative to the stalling foot. Some might consider this the 'double cross-body position'.
Requires good flexibility and coordination.
Jorden Moir
Monster is the trick in the first couple seconds of this video (after the clipper and before the swirly mess-up thing
http://v.footbag.org/media/203/Whateva.wmv
There is no scooping motion. That's a different trick.
There are two ways you could think of it:
1) a frigidosis wrapped around the support leg
2) a backspinning inside stall with zero upper body movement
Jorden Moir
- zeroman13
so monster is like a clipper but in front of your support leg? Would you set your body into a clipper position then catch the delay in front of your support leg?
