Refraction
Refraction
Refraction
SET >> INSIDE [DEL] > (BACK) SPIN [BOD] > OP OUT [DEX]
Hi, i looked out if there was anything in this section about that moove. So, when i looked out at footbag.org, it is a 3 adds moove. But if we think about a butterfly ended with an osis, it makes a 4 add. Anyway, people seems to dislike that moove, and i was warned to not to do it (from many footbaggers). But if we think about a double over down ended with an osis (don't remember the name of the moove), that seems ok. I don't really get the point of not doing a refraction (a moove that we almost never see in vids). If i could get some opinion about it, it would be great. Thanks.
Augustin Tiffou
75 adds
RNH
75 adds
RNH
Don't listen to anybody who says that *ANY* footbag move isn't awesome. Refractions are SWEET. Double down ending in osis is motion (or ocean is another variation...far, or toe-set, or something...). Lon and Allan do these sometimes on internet videos I've seen (refraction not motion). I actually don't really have any tips, I just wanted to stay on topic while addressing a few things.
I don't know if this is proper, but when I've done them I've thought osis in front of my body, but pulled behind the support leg. I'm not sure if this is clean or anything, so maybe don't listen to me
PS: I edited your post with the Job's -- I wrote it differently than Footbag.org because I feel this describes the move better, but I'm a little unsure -- feedback on that would be helpful.
- slapdash21
- Futureless
yeah, i think the best way to explain refraction is a slurry symple butter or an osis where the bag drops between your leg instead of on the outside of your leg
edit- oh yeah, i forgot to mention...erik said it perfectly already, but to reiterate, dont let anyone else decide what moves you do...i personally think refraction kicks ass and i do it all the time. it can also be a very impressive and difficult concept when you put different cool sets on it. pogo (symp stepping) same refraction, for example, is a highly styley and fairly difficult 4 add move.
Pete Bowler
B$C
keeps it offah da ground.
617 FOR LIFE
B$C
617 FOR LIFE
- Iron Clad Ben
- Superior Precision Bionics
Thanks Matt for your post. I think refraction can be really cool with a zooming after. I think can definitely take an other dimension in the way we're using it in a run. It' sure that is an easy 4 add, as the osis is an easy 3 add. thanks for the posts, it's always nice to have different opinions from different footbaggers.
Augustin Tiffou
75 adds
RNH
75 adds
RNH
Hi iron, refraction is like a butterfly, but the leg that is dexing delay the bag in osis position. The only vids that i've seen with a refraction is in videojam 7 (in the vids section). The vids to choose is videojam. If you look caredully during the battle between Robinson and Pierrot, Rob hit's a refraction pretty clean. This is the only link i know for this moove.
Augustin Tiffou
75 adds
RNH
75 adds
RNH
- zeroman13
Isn't a refraction like a symp butterfly??? Thats what I always thought it was.
I have always thought of it as a miraging op side butterfly and I think it can be done clean if the first dex is done big enough and the delay is not pulled through to complete the second dex. Dyno is rev whirling osis.
Jon's FootBlog
MSN: jon.haber@gmail.com
hackeysnacker wrote:Jon it almost sounds like you're describing dada curve.
Yes I am My mistake.
Jon's FootBlog
- Zeb Jackson
i will quote what daryl genz told me about a refraction.....
"Its a Glorified Osis" which it pretty much is, by itself its an ok trick but it look ultra sexy if you put in a ducking before it
speaking of which this week was the first week that i actually landed ducking refraction !
-Zeb Jackson
http://www.elitefootbag.com
I'm not sure if this is right but from what i've seen i dont think refractions are butterflies ending in osises (osi? lol). Say your doing the move with your left foot, in a butterfly you left foot would dex over the bag giving you three adds (+2 from clip) but with refraction i dont think that foot dexes over the bag like a butterfly, its just an inside stall with a spinning wrap thing so i think it should just get 3
To get back to cammel explination, i think wa can see the refraction as a 4 adds moove (dex (1) + osis(3)). I'm considering the delay as an osis rather an inside delay cause the delay is behind you, and, as an example, we can have the feel of a zooming after a refraction, not with the inside delay. Also, if it isn't finishing with an osis, it's rather a some sort of butterfly than a refraction. Maybe 'im wrong, but it's what i think.
Augustin Tiffou
75 adds
RNH
75 adds
RNH
