Ducking Torque
SET >> DUCK [BOD] > SAME/OP IN [DEX] > BACKSPIN [BOD] > OP CLIP [XBD][DEL]
Where should the bag be set for this, I seem to regularly miss the bag by a few centimenters. I'm setting from toe and have really bad ankle crank. Any other tips for torques in general would be good too
Ducking Torque
the bag should be set straight up just above your neck - the same as for all ducking tricks.
My advice for this trick is - get to a stage where you can hit pdx torque midstring out of anything all the time - or at least so it is a really strong move for you - then ducking pdx torque is not that hard. Same goes for all ducking moves. Obviously you also want to really school ducking stuff.
