janis
by janis » 18 Oct 2006 02:39
Pixie/Open Merlin
TOE > SAME IN [DEX] >> OP IN [DEX] > (NO PLANT WHILE) OP IN [BOD][DEX] > OP TOE [DEL]
this trick is giving me lots of trouble, any tips would be greatly appreciated.
- Modifiend
by mc » 18 Oct 2006 20:12
I'm guessing that, because you're asking about the trick with a set in front of it, that you can hit merlin. and, if you're a toe-to-toe player, you probably have a pixie set. So practice getting that pixie set to peak right above your belly button, and practice a downtime merlin that you attack right as the bag is peaking, then put the two together. make sure to put all your weight on the leg that is doing the 3rd dex so you can spring off it right after the 2nd dex. and don't the your merlin!
janis
by janis » 18 Oct 2006 23:39
ok thx for those tips, I'll try attacking the second dex more
yeah I can hit merlin both sides and duck/dive/spin from pixie, for some reason there's a huge problem with this trick (probs because it's hard)
Cod
- Flower Child
by Cod » 21 Oct 2006 15:09
It is important to start Miraging dex as soon as possible. High Pixie set is not necesary. Fast Pixie set will help. And maybe try at first some Pixie ss Reverse Flails to be sure the last dex is clean.
Michał Biarda (Me-how Be-r-da)
janis
by janis » 22 Oct 2006 01:28
thanks for the tips Cod
