Training your Symp
Training your Symp
I was trying Smyp Dlo and Eggbeater today, and wasn't even coming close to jumping high enough. Does anyone have any ideas on how to cross-train the jumping muscles you need for symposium dexes?
There are different muscles used for just about every different symp move. You don't use the same ones for symp whirl that you do for symp dlo.
I think you will find, that for most symp moves it's more about training your legs to do dexs midair (with no help from a support leg), than it is about jumping higher.
Just need a little more co-ordination!
To answer the question at hand - the best cross training I can think of is skipping - Although I haven't tried it, I imagine skipping would help more than anything else I can think.
I also agree with Nic that symp moves aren't really about how high you can jump. When you're watching vids of people doing symp moves - watch their heads - which don't have a great deal of lateral movement. It's more about bringing your knees up high - so if you're watching the feet it looks like you're high off the ground and then pushing them back down.
Do speed- and dynamics-training for your legs. I don't have enough knownledge to write how should you train, but you can do some research with google and other search engine.
Pawel Ptaszynski
NAS
Be strong, LIVESTRONG
http://www.laf.org
http://www.wearyellow.com
NAS
http://www.laf.org
- slapdash21
- Futureless
before you think about hitting symp dlo, can you hit 10 symp mirages in a row? Would consider that hard? or easy? If easy, then practice hitting symp mirage a bit quicker so that you have more time left at the end of the move. You need enough time to hit legover from it. Symp dlo isn't really a dlo done symposium, its more like a symp mirage with a legover. Hitting the hard symp tricks is really all about maximizing the time you have to hit that last elements of the trick because you have finished the first parts more quickly than normal.
- Paul Agostinelli
- funklovesfootbag
- Womanizer
- save.cullen
